WTS Lancair 320/360 Carbon Backplate and Spinner
Postby Chris Zavatson » Sat Apr 18, 2015 11:43 pm
I have another batch of carbon back plates available.
These are made of high temperature epoxy cured at 350 deg F and 150 psi. Precision milled bolt and hub pattern fits the Hartzell compact hub. $275
Light Weight Carbon Spinners also available. $250
(includes section to back fill behind blades)
Re: WTS Lancair 320/360 Carbon Backplate and Spinner
Postby Richard Browne » Tue Oct 18, 2016 2:59 am
Hi Chris
Still got these for sale mate?
Richard Browne
Postby Chris Zavatson » Tue Oct 18, 2016 1:22 pm
Richard,
Yes these are still available. I try to keep one set ready to go for those unexpected AOG situations.
Last one was an unfortunate bird strike.
Postby Richard Browne » Thu Oct 20, 2016 3:36 pm
OK super, can l hold off for a month or two? l'm not heading back to South Africa until after Christmas, l'll take one off you then.
I have the McCauley prop on my io360 - should be ok?
All the best Chris
Richard
Richard Browne
Postby Chris Zavatson » Sun Apr 23, 2017 7:09 pm
I have two more spinners and four back plates in case anyone needs one.
Postby Daniel Switkin » Sat May 13, 2017 11:52 pm
I saw these today in person, they are beautifully made!
Daniel Switkin
Legacy enthusiast
Postby Chris Zavatson » Wed Nov 29, 2017 12:07 am
To answer a few questions globally.....
Despite being a somewhat older post, these parts are still available. I try to always keep backplates on hand to quickly cover folks that discover cracks in their original aluminum version.
And for those that like the carbon look, the spinner does not need to be painted.
Postby Erno Ovari » Wed Nov 29, 2017 9:23 pm
I bought one back plate and a carbon spinner from Chris last year for my 360. They are truly the highest quality products. Installed easy and they look amazing.
No need to paint the spinner, whatever color your plane is it fits
Installed in 30 minutes
Erno Ovari
Postby Chris Zavatson » Sun Nov 18, 2018 12:31 pm
Bump Up.
The spinners and back-plates are still available. I try to keep some ready to go for those 'found a crack in my aluminum back-plate AOG situations'
Some pics during installation.
prop cut-out pattern
rough cut prop cut-out
fine tuning clearance
transferring back-plate hole pattern to spinner
prepping for nut plate pad layup
fabricating nut plate pad
alignment for drilling support screws
Transferring hole to filler section
Done
Postby Dan Olsen » Sun Nov 18, 2018 3:04 pm
My AL backplate has cracked over the years, I've stop-drilled which bought be more time but finally put one of Chris's Carbon backplates on last year and it is solved for good. Fantastic workmanship on the part... wish this had been the backplate available years ago when I built.
Thanks Chris!
Dan Olsen
N320DK - 1100hrs
Dan Olsen
Building IV-P
Users browsing this forum: No registered users and 10 guests
