WTS Lancair 320/360 Carbon Backplate and Spinner
Re: WTS Lancair 320/360 Carbon Backplate and Spinner
Postby Paul Miller » Sun Nov 18, 2018 4:11 pm
These are really stunning pieces of work. Would there be a possible Legacy version? Would a batch buy make it more attractive? I have to believe there is interest.
Postby Jim Anderson » Sun Nov 18, 2018 7:17 pm
Chris: I need a spinner/bulkhead, etc. for my ES with Mcauley, IO 550. Got anything to fit?
Jim Anderson
ES building
Postby Sean Tommervik » Sun Nov 18, 2018 10:40 pm
Chris, anyway to make one to fit my Catto?
N324H
Sean Tommervik
enthusiast
Postby Chris Zavatson » Mon Nov 19, 2018 7:56 pm
Paul Miller wrote:These are really stunning pieces of work. Would there be a possible Legacy version? Would a batch buy make it more attractive? I have to believe there is interest.
Paul,
Anything is possible. :) Originally I got into spinner fabrication to replace my own. A pro-football sized dude used my spinner as an arm rest and when he pushed himself off, everyone around heard that cracking fiberglass sound.
Then there was the propensity for the 360 to crack aluminum back-plates. I had a 250F cure prototype on my plane for 16 years. Local 360 acquaintances were suffering back-plate failures, so I went ahead and had a male/female mold made for use with 350F cure material.
I don't know much about the Legacy spinner - don't even know the diameter. Up front investment in molds is the big hurdle.
Jim Anderson wrote:Chris: I need a spinner/bulkhead, etc. for my ES with Mcauley, IO 550. Got anything to fit?
Jim,
Unfortunately not. At the moment all I have are 12" spinners primarily for the 320/360 series.
Postby Chris Zavatson » Mon Nov 19, 2018 7:57 pm
Sean Tommervik wrote:Chris, anyway to make one to fit my Catto?
Sean,
Yes. There are some on fixed pitch installations. I just need to save a blank back plate and not mill the hub pattern. At the moment everything on the shelf is already milled for the Hartzell constant speed.
Postby Jim Anderson » Mon Nov 19, 2018 8:04 pm
Thanks anyway,Chris.
Jim Anderson
ES building
Postby Darcy Wingo » Tue Dec 25, 2018 8:39 pm
Chris Zavatson wrote:I have another batch of carbon back plates available.
These are made of high temperature epoxy cured at 350 deg F and 150 psi. Precision milled bolt and hub pattern fits the Hartzell compact hub. $275
Light Weight Carbon Spinners also available. $250
(includes section to back fill behind blades)
Hello Chris,
I am very interested in a complete Carbon Fiber spinner, but I would need it to fit my 3 blade whirlwind propeller. Do you offer these as turn key units?
Thank you
Darcy
Darcy Wingo
rank-235
Postby Chris Zavatson » Thu Dec 27, 2018 10:59 am
Darcy Wingo wrote:
Hello Chris,
Thank you
Darcy
Darcy,
The typical back-plate is drilled/milled for the the Hartzell hub. For a handful of other props, I have skipped the hub cut-out and only drilled a center pilot hole. I am not too familiar with Whirlwind props. I see on their website they have many hub styles.
The typical spinner has two re-enforcing pads where the prop blades exit. These are to slightly stiffen the edge of the blade cut-out. There is no reason one couldn't be made with three pads. The blade cut-outs are left to the owner builder as the actual blade type and blade position will be a bit different on every installation. I do include back-fill pieces to fit behind the blades after the blade opening is finished. This just means you don't have to try to salvage the cut-out to use as back fill.
Postby Danny Miller » Sun Aug 11, 2019 9:58 am
Chris, is your hole transfer tool home made or can it be purchased? I was thinking of getting a set of hole transfer punches but this little tool you have looks like it might work better.
Danny
LNC2-II
Aerospace Engineer
EAA Technical Counselor
EAA Flight Advisor
A&P
Old but not bold
Danny Miller
PreviousNext
Users browsing this forum: No registered users and 19 guests
