ES-P 2008 For Sale $285,000
Postby Justin Williams » Mon May 04, 2015 6:36 pm
It pains me to sell this beautiful machine! It has made a fantastic commuter plane for the last few years but I am relocating. This is an extremely capable cross country aircraft. It will haul anything you throw in it and get there quickly at 29,000 feet in pressurized comfort. I may consider trades down if you want to bring cash to the deal. Insurance rates for the ES-P are a quarter of the IV-P. I am the second owner. The aircraft was built out in Redmond to very high standards. You can find it at Leesburg, VA (KJYO) or Monroe, NC (KEQY).
http://www.barnstormers.com/classified_ ... +2008.html
Last edited by Justin Williams on Thu Apr 26, 2018 7:34 am, edited 5 times in total.
Justin Williams
ES-P
Re: ES-P 2008 For Sale $300,000
Postby Brian Thompson » Tue May 05, 2015 10:35 am
29000FT?
I thought the ES-P had a 25,000FT ceiling as well as the ES
Lancair Super ES - TN
Dual Garmin G3X Touch, GTN750/650
980hrs and counting...
Brian Thompson
estn
Postby Justin Hawkins » Tue May 05, 2015 11:59 am
I just got a call from a gentleman last week looking for an ES or preferably an ESP, I passed the info onto Kim give her a call if you would like his info. 541-923-2244 or kiml@lancair.com
Pretty sure there is a restriction and you cannot fly above flight level 280.
Justin Hawkins
Risse
Postby Brian Thompson » Tue May 05, 2015 12:32 pm
as a member of the lancair fleet in which would ultimately be affected by any insurance claims, the TIT and fuel flows for that power setting concern me
That's not LOP, by any measure- and why fly at 28000ft with a 39KT headwind? What is your typical TAS at those attitudes?
I can reach 222KTAS at 18000FT with my TN setup, I would expect to get higher speeds by climbing further, but have not had the right masks and copilot to do so yet
Brian Thompson
estn
Postby Justin Hawkins » Tue May 05, 2015 2:01 pm
ES-P spec doc pdf
ESP Spec sheet.pdf
(501.18 KiB) Downloaded 148 times
Justin Hawkins
Risse
Postby Justin Williams » Tue May 05, 2015 8:29 pm
Put this in your pipe and smoke it.
https://drive.google.com/file/d/0B4R1g9 ... sp=sharing
By the way, 222 kTAS burning 15gph at 1642 TIT and 62% power is easily LOP and very safe.
Justin Williams
ES-P
Postby Paul Miller » Tue May 05, 2015 10:02 pm
Dang. Can't argue with that. My point was that FL250 should be easy. I can't fly at FL290 so not sure how anyone else can without RVSM but regardless those are nice speeds and nice fuel flows and it is the flight levels. I hope you get a quick sale, it looks like a nice plane. Do you have pix to post here?
Postby Justin Williams » Wed May 06, 2015 8:29 pm
Picture attached
Shiny
Justin Williams
ES-P
Postby Brian Thompson » Sun May 10, 2015 7:25 pm
Justin Williams wrote:Put this in your pipe and smoke it.
What's your peak TIT? Do you have any engine logs you'd share?
Brian Thompson
estn
Postby Justin Williams » Mon May 11, 2015 6:41 am
Pressure altitude does not equal actual altitude.
No engine logs. Peak TIT at these high altitudes is well beyond the turbo operating max of 1750F. You lean to TIT or fuel flow in these cases while understanding the lean box limits.
Justin Williams
ES-P
Users browsing this forum: Mike Soh, Nicolas Charette, Sam Silverstein and 17 guests
