WTS, 235/320/360/Legacy Hydraulic Pump Controller
Re: WTS, 235/320/360/Legacy Hydraulic Pump Controller
Postby Paul Miller » Mon Jul 18, 2016 11:10 am
Balsa wood prop? :no:
Postby Jon Hults » Mon Jul 18, 2016 12:13 pm
Thanks Chris. Not sure yet what the temps are going to be up there or whether we'll put the hyd pump and other mechanicals in an enclosure/compartment protected from the "engine room"....but I do need that stuff up there for CG.
Or...it might be easier to leave the hyd pump alone and just move the engine even further forward! Love this stuff!!! ...but probably treading off topic here. I do like the balsa prop idea though! ;)
Jon
Jon Hults
Temecula, CA
Legacy N222BZ
(...under construction!)
Jon Hults
L2k-building
Postby Jon Hults » Sat Aug 06, 2016 10:23 am
Hi Chris,
I've got to have one of your controllers. Please let me know the payment particulars and I'll send it along. What a great product!
Thanks,
Jon
Jon Hults
Temecula, CA
Legacy N222BZ
Jon Hults
L2k-building
Postby Chris Zavatson » Sat Aug 06, 2016 11:32 am
Jon Hults wrote:Hi Chris,
Thanks,
Jon
Jon,
PayPal or check works. I'll PM details.
Chris
Postby Bill Harrelson » Wed Sep 14, 2016 8:06 pm
Chris,
Could this be used in place of the solenoid on the IV?
See ya next week in Fairhope.
Bill
Bill Harrelson
harrelson
Postby Chris Zavatson » Wed Sep 14, 2016 8:14 pm
Bill Harrelson wrote:Chris,
Bill
It most likely can. Do have a pdf of the gear electrical schematic for the IV?
Postby Bill Harrelson » Wed Sep 14, 2016 8:19 pm
Chris,
I don't have a schematic available at the moment but I could forward one tomorrow. The IV uses valves to control gear and flaps. The solenoid operates the pump strictly according to the single pressure switch and only in a single direction. Quite simple electrically.
Bill
Bill Harrelson
harrelson
Postby Chris Zavatson » Wed Sep 14, 2016 8:33 pm
Bill
Bill,
That is what I suspected. In that case you would just use one side of the gear controller.
Chris
Postby Chris Zavatson » Fri Oct 07, 2016 11:24 pm
Installation instructions attached for reference.
installmanual_v1.12FR.pdf
(913.48 KiB) Downloaded 510 times
Last edited by Chris Zavatson on Wed Nov 07, 2018 12:56 am, edited 1 time in total.
Postby Bob Fidler » Tue Oct 11, 2016 7:40 am
I have been told the pump used on Glasair retractables is basically the same pump. Therefore, this controller should work fine. Any comments?
Bob Fidler
PreviousNext
Users browsing this forum: Brian MacKenzie and 8 guests
