WTS High Performance Calipers for 360 Outback Gear
Re: WTS High Performance Calipers for 360 Outback Gear
Postby Roger Iverin » Sat Jun 20, 2020 2:51 pm
Are these cast in steel? And steel pistons?
How much are the weigh increase actually, i believe its a very good trade but just curious.
Best regards
Roger
Roger Iverin
N360DF in progress.
"Likes to improve stuff"
Roger Iverin
360 building
Postby Chris Zavatson » Mon Jun 22, 2020 12:56 am
Roger Iverin wrote:Are these cast in steel? And steel pistons?
Best regards
Roger
Roger,
Both the housing and pistons are aluminum.
The original Matco single piston caliper is 546g. The new triple piston caliper is 1015g.
Postby Roger Iverin » Tue Jun 23, 2020 1:44 pm
Thanks Chris,
Was just little confused since you mentioned titanium.
I did not think its was lighter. But I assume you would redesign the dimension with titanium
and get the same strange and lower weight.
Roger
Roger Iverin
N360DF in progress.
Roger Iverin
360 building
Postby Chris Zavatson » Tue Jun 23, 2020 2:20 pm
Roger Iverin wrote:Thanks Chris,
Roger
Hadn’t really considered titanium at the time. It would cost a fortune, for sure. Just for kicks, I looked up the cost of a bar on McMaster 1”x 3/4”x12”. $227. There are probably cheaper sources, but you get the idea :wink:
Postby Roger Iverin » Tue Jun 23, 2020 6:55 pm
Quite intresting actually!
:pop:
Roger Iverin
N360DF in progress.
Roger Iverin
360 building
Postby Chris Zavatson » Sun Sep 20, 2020 7:26 pm
Three more sets are assembled and ready to go.
Postby Chris Zavatson » Sat Apr 10, 2021 8:47 pm
just assembled a few more calipers.
Postby Chuck Walker » Sun Apr 11, 2021 2:02 pm
Wow, Chris. My legacy has Cleveland 30-133 brake assemblies with one piston and two 66-105 brake pads per wheel. No wonder braking is anemic. Steering is no problem but braking after landing is problematic at best. I don't suppose my Legacy setup would be compatible with your caliper? The master cylinders might need to be bigger to accommodate three pistons, too. I wonder if Cleveland makes a larger caliper that would improve braking efficiency and would be a drop-in replacement for their 30-133 brake assembly? Anyone?
Chuck Walker --- L2K 138 --- N27EB
Chuck Walker
Postby admin » Sun Apr 11, 2021 4:05 pm
Chuck, try a search on "Legacy+Cleveland+brakes" and there are a lot of topics. I think we should move this discussion on Legacy brakes to Legacy forum or the maintaining forum for brakes.
Trouble with photos or login or passwords or avatars or anything, you can PM or email or simply call. you can use text and skype also.
USA 406-873-8311
Canada 587-432-7536
Postby Chuck Walker » Sun Apr 11, 2021 4:28 pm
Great idea, Paul. No problem. Thanks.
Chuck Walker
Previous
Users browsing this forum: admin, Bing [Bot] and 25 guests
