WTB: Floor mounted adjustable rudder pedal
Postby Danny Miller » Fri Apr 19, 2019 1:23 pm
I want to do some testing on one of these. I don't need the pedals or master cylinders, just the adjustment system and probably the mounting tubes. Maybe you upgraded to a better system and have one of these laying around? Maybe you know where one can be had from a wreck?
Danny
LNC2-II
Aerospace Engineer
EAA Technical Counselor
EAA Flight Advisor
A&P
Old but not bold
Danny Miller
Re: WTB: Flr mounted adjustable rudder pedal
Postby Danny Miller » Mon Apr 29, 2019 7:17 am
I'm still looking if anybody has one.
Danny
LNC2-II
Aerospace Engineer
EAA Flight Advisor
A&P
Old but not bold
Danny Miller
Re: WTB: Floor mounted adjustable rudder pedal
Postby Mark Huffstutler » Mon Apr 29, 2019 4:41 pm
Lancair has new units in stock. Contact Robert Clark at 830-900-7032.
Mark Huffstutler
lancair mark
Postby Danny Miller » Tue Apr 30, 2019 6:36 am
Mark Huffstutler wrote:Lancair has new units in stock. Contact Robert Clark at 830-900-7032.
Thanks Mark but I don't need a new unit, or the big expense that goes with it. I want to see if it's possible to extend the sliding tubes another 2"-3" to accommodate a person with short legs.
Danny
LNC2-II
Aerospace Engineer
EAA Flight Advisor
A&P
Old but not bold
Danny Miller
Postby Roger Iverin » Tue Apr 30, 2019 7:39 am
Danny, I am in this research myself. And I see two option. Just move the unit or extend the slide tube
as you mention. Should work perfect.
Just open a topic in building & maintenance if you want.
Regards units: Many have removed right side for less weight.
Roger Iverin
N360DF in progress.
"Likes to improve stuff"
Roger Iverin
360 building
Postby Danny Miller » Tue Apr 30, 2019 7:49 am
Roger,
It might be easier for you if you haven't installed them yet. Mine are already installed so I want to use the existing mounting location. I suspect this means I'll have to machine a new end cap in order to accommodate the longer tubes and floor mounting location. It may also mean a beefier end cap to avoid bending.
Danny
LNC2-II
Aerospace Engineer
EAA Flight Advisor
A&P
Old but not bold
Danny Miller
Postby Roger Iverin » Tue Apr 30, 2019 9:05 am
Danny Miller wrote:Roger,
No mine is installed as well. Pretty sure it us plenty to just extend the tube.
I can take a picture to show you. My header is off. But we should open a topic for the issue.
Roger Iverin
N360DF in progress.
Roger Iverin
360 building
Users browsing this forum: Bing [Bot], Steve Alderman and 30 guests
