WTS: LANCAIR IV N1228E 1200 TTSN $175,000
Postby Harvard Holmes » Mon Oct 07, 2019 6:00 pm
Description
This Lancair IV was completed in 1998 from a kit purchased in 1992. It has slow build wings and a partially fast build fuselage. The builder had done two aircraft restorations before undertaking this Lancair IV.
The builder chose a non-pressurized Lancair with a normally aspirated engine to achieve light weight, simplicity, and economy of operation. The empty weight is 1970 pounds, and the gross weight is 3300 pounds. You can have 90 gallons of fuel, 800 pounds of passengers, travel 1000nm in 5 hours, and have 2 hours reserve at the end of your trip.
We are selling our Lancair IV now that we have finished building our Lancair IV-P.
Log book scans are available upon request.
Airframe and Engine: Total Time: 1170 hours
Registration: N1228E Serial: LIV 190
Empty Weight: 1970 lbs., MTOW 3300 lbs.
Engine: Continental IO 550-G Left magneto, right electronic ignition
Propeller: Hartzell PHC-H3YF, 3-blade semi scimitar
Speed Brakes: Precise Flight
Door Seal: Electrically operated
Fuel Capacity: 88 gallons usable
Brakes: High energy Cleveland
Oxygen: 4 overhead outlets
Leather seats: Tempur foam – very comfortable
Avioncs
Primary Flight Instruments – Analog gauges
Engine Monitor – Vision Microsystems VM-1000
GPS Com – King KLX 135A (VFR), coupled to autopilot
NAV/Com – King KX155 with glideslope
Moving Map – KMD150
Intercom – PM6000
Autopilot – Century 2000 with altitude hold
Transponder & ADS-B in/out – Lynx 9000 panel display traffic/weather & WiFi
ELT – ACK E-04 with GPS input
Trim Systems: 3 Axis electric trim
Performance
200 KTAS at 8000-10,000 ft on 12 GPH lean of peak
Contact
Harvard Holmes 510 684-6309 or HarvardHolmes@comcast.net
Harvard Holmes
IV
Users browsing this forum: Stefan Hartung and 32 guests
