WTB. (Fuel injector IO-550). HELP
Postby Phil Sciuk » Fri Nov 22, 2019 2:01 pm
Need a fuel injector
I believe the part number is 652312-12E
Phil Sciuk
Re: WTB. (Fuel injector IO-550). HELP
Postby Christopher Toscas » Fri Nov 22, 2019 2:12 pm
mine is pictured,
most easy is to look at the others and get same
Christopher Toscas
IV
Postby Phil Sciuk » Fri Nov 22, 2019 2:28 pm
It’s stamped 12E
Phil Sciuk
Postby Christopher Toscas » Fri Nov 22, 2019 4:05 pm
ok,12E, P/N shall be the good one, I may check it some next day in the O/H manual (hangared), congratulations for bottom part successful unbolting.
For new one, use Teflon spray and no more anti-seize,
also put it on O-rings to slip cap easily.
If same trouble with other injectors, heat before unbolting with teflon also.
I tell it because I swapped many times one injector with one other to minimize FF spread.
Christopher Toscas
IV
Postby Christopher Toscas » Sun Nov 24, 2019 8:49 am
parts list : labelled "jet", P/N 627333-12, not checked if updated since printing date.
Christopher Toscas
IV
Users browsing this forum: Arvid Josefsen, Brian Campbell, Christopher Toscas, Todd Johnson and 37 guests
