LancairTalk works with prospective buyers with issues like hangar, insurance and training.
We do a lot of work to compare this aircraft with other aircraft clients wanted to look at. Using flight plans for typical missions we develop profiles for trips and highlight things like pax capability, max range, fuel reserves at destination, CG issues, Gross Weight limitations, avionics, training options and insurance options. LancairTalk will assist clients to get the best rate possible using our proxy method for insurance quotes. LancairTalk will not let buyers get blocked or registered from getting competitive quotes by certain insurance brokers or underwriters like Gallagher or Falcon, for example.
We can also help compare data like engine reserves, maintenance costs, fuel burns, typical trip costs, training costs, database fees and lots more. The people who do their homework soon realize that Lancairs and IV-PT models have very few equals in a single-engine airframe and certainly none at this price point.
Here are a few of the features on this Lancair.
Panel- Carbon Fibre
- VR601 TSLM: features temperature limiting auto-start
- BETA limiting
- AFO – anti-flameout
- VR Avionics AFL (auto fuel leveling)
- VR Avionics prop heat controller
- G900X dual screen, dual GIA 64 WAAS Nav/ Com units with 16 Watt transmitting power
- Triple AHRS/Air Data Computers - GSU 73- GSU 25- GRS 77 /GDC 74
- Dual GMU 44 magnetometers
- All GARMIN LRU’s are independently powered via a dual bus
- TCAS GARMIN GTS 800 with dual four pole antennas
- ADSB out GTX 33 ES
- ADSB in GDL 39R
- Dual GTP 59 OAT temp probes
- 3-Axis (3 GSA28 servos) AP features with “ ESP” function and auto levelling button
- Audio panel
- G3X Touch
- GMC 307 autopilot – full 3 axis
- Electric trim – pitch, roll, yaw
- Infinity Control Stick
- Lancair Switches (Boost Pump, Start, Generator, Transfer Pumps L,R, Batt 1, Batt 2, Cross-Tie, Av
Master, Vent, Pitot Heat, Prop Heat, FlowPac, Landing Lights, Nav Lights, Strobe Lights, Autopilot - Pressurization Controls – setting gauge, pressure gauge, dump switch
- Gear Switch (panel top)
- Flap Switch (panel bottom)
- Isolate Switch (safety type)
- annunciations are shown on the VR Display. The G900x and G3x have a a Master warning light
connected to the G3X Master Alarm Light (panel top) - USB charging port
- VPX Pro
- Triple GPS Waas
- Garmin Pitot / AOA
- ELT switch & alarm
- Defrost vents
- current IFR pitot/ static certification with a leak rate of < 100 ‘ at up to 30,000’
Electrical - Electrical system is dual buss with Generator and Lamar GC 11 GCU on bus 1 and a B&C 20 AMP
alternator with B&C LS 1 regulator on buss 2 - Cross tie contactor connects the buss 1 and buss 2.
- Circuit Breakers protects buss 1 and VPX - Pro controls buss 2
- Dual 24V batteries
- External GPU connection (with cover)
- Electric Flaps controlled with VPX Pre-select
Air Conditioning - Engine driven
- Condenser (below baggage compartment)
- Evaporator (above / behind rear seat)
- Overhead vents (front and rear)
Lighting - Aveo interior lights
- XE Vision XV-19 HID lights (2)
- Aveo strobes / position lights (wing tips, tail)
- Panel back-lighting
- Switch back-lighting
Gear - Main gear disassembled and overhauled
- Nose gear strut overhauled and updated by Lancair
- Nose gear doors – carbon fibre
- Main gear doors – extreme stiffening
- New main tires (Goodyear)
Engine - Walter M601D EXP Turbine engine, 740HP Max(5 minutes), 657HP continuous
- 63 hrs. since IRAN
- Upgraded & Overhauled FCU (Jihostroj) with warranty
- Prop Hub IRAN by Dimech
- Prop Governor Overhauled (Jihostroj) with warranty
- Avia Props: 3 blades matched by Avia (1 < 100 hrs, 2 at 63 hrs)
- Prop De-Ice
- Prop Balanced
- EPA can
- High Temp ablative firewall coating
Interior - All panels fully removable (incl. overhead)
- Two tone grey with French stitching
- Silver seat belts
- Front seat belts: 4 point inertial reel
- Covered halon fire extinguisher
- Covered emergency Oxygen
- Front seats have lowered carbon fibre base for more head room
Intercom - Front: 3 jack connections – pilot, co-pilot
- Rear: 3 jack conns. Each side
Pressurization - Dukes Outflow
- 2 gauge panel controls
- Flow Pack driven
- 5,500’ cabin at FL 190
- Cabin altitude warning above 12,000 feet displayed on the GDU
Fuel System - 188 gallon, fully calibrated
- Fuel probes all tanks
- AFL (auto fuel leveling)
- Baggage, Belly, Left Wing act as 1 Tank
- Transfer pumps to Engine on both Wings (with check valves)
- AFL controlled by VRX
- Header tank with air vent and filter
- Full time Boost Pump
Cowl - New style inlet (similar to TBM)
- Engineered ducting and plenum
- NACA duct for oil cooler and air cooler
- Bottom vents (2)
Hoses - Teflon inner, stainless braided exterior (brakes & hydraulics)
- High temp. for oil (heat covered also)
Windows - No scratches or marks, flawless
Flight Testing, Training - aircraft and systems were so well made and functional that the first test flight was 2 hours long
- Chris Rust pilot
- 25 hrs test flown. (Canadian requirement)
- Type Rating required in Canada for all Lancairs
Wing Tips - Freidel tips (German design)
- Improved handling, cruise, stall
