UPDATE March 31, 2022 Free Lancair with purchase of oil and filters for $99,999
The owner has two sets of spares (parts and jacks) that he will deliver personally anywhere in the USA.
(Extended Wing Tips, Larger Elevator, & Larger Rudder)
Some features of this Lancair:
- 2 Axis Auto-pilot
- S-Tec Altitude hold
- Strike Finder
- 340 Garmin Radio
- Bendix King 152
- Garmin GNS-430W
- Garmin GTX-33ES Transponder
- Variable Speed Prop
- 2x Dave Clark Stereo Headsets
- ADS-B out compliant
- Cruise: 190 knots
- Burn: 9.5 gallons per hour at 10,000 ft
- Range: 1,000+ miles per tank (56 gallons)
- Extended wings and tail / Strobe lights and landing lights
- All building plans and manuals
- spare original leather for repairs and replacement
- Located in Pennsylvania
And YES there are spare parts. Available to purchase is an extra set of...
- Main wheel rims, tires, and tubes.
- Hydraulic reservoir.
- Brake pads.
- 2x extra Dave Clark Stereo headsets (total of 4).
- Bendix KING 135a radio (this is a extra radio not the one in the plane)
- 2x sets of Jack Stands
- Auxiliary Oxygen System w/ special filler hoses & connections
- Rebuild kit for Hydraulic ram on the landing gear
- External preheat heater (to warm engine in winter)
- Several oil filters
- Tie down pins / ropes
- 2x custom made 360° Wheel dollies (for front wheel to help park the plane in the hanger)
- Stainless steel wheel covers (this replaced the standard plastic covers that crack all the time)
- Survival gear (2 standard life jackets, 2 compact life jackets, 20 ft fluorescent ribbon, portable ELT, etc.)
- Sporty's SP-400 Handheld transceiver (portable handheld radio)
- 2x Lycoming valve cover gaskets
- Regulated 12-volt power supply for the 135a radio
- External battery charger
- Extra set of wheel bearings
- Various other small parts (strobe light bulbs, nuts/bolts/screws, etc)
