WTS - New Parker clone pump with LB circuit
Postby Chris Zavatson » Sun Mar 07, 2021 3:28 pm
This is a new Parker clone pump with the LB back pressure relief circuit.
Equivalent to Parker number:108AMS32-CLB-3V-16-12
-.032 cipr gear section
-PRV - pressure relief valves - are set to up 1,600 psi, down 1,200 psi.
-TRVs -thermal relief valves- on both high and low sides
-12V
-T-fittings for pressure switches installed.
-Bench tested, holds pressure all day, both directions.
$500 plus shipping
Last edited by Chris Zavatson on Sun Mar 07, 2021 3:39 pm, edited 1 time in total.
Re: WTS - New Parker clone pump with LB circuit
Postby admin » Sun Mar 07, 2021 3:35 pm
Chris, excellent! Voltage(s) ? Do you have the switches (if not they are available on this site) and sensors for displaying on EFIS devices can be inexpensively added also.
Trouble with photos or login or passwords or avatars or anything, you can PM or email or simply call. you can use text and skype also.
USA 406-873-8311
Canada 587-432-7536
Postby Chris Zavatson » Sun Mar 07, 2021 3:41 pm
admin wrote:Chris, excellent! Voltage(s) ? Do you have the switches (if not they are available on this site) and sensors for displaying on EFIS devices can be inexpensively added also.
Added voltage. The "AM" designation is the 12V motor.
I don't have switches. I've used both SUCO (mechanical) and now ProSensse (solid state)
Postby Lex Thistlethwaite » Mon Mar 08, 2021 1:51 pm
Chris,
I’ve read through various forum threads to try to sort out suitability of this pump for a Legacy. I thought I’d just ask you directly. Is this pump suitable for a Legacy?
Lex Thistlethwaite
Postby Chris Zavatson » Mon Mar 08, 2021 6:03 pm
Lex,
Short answer is yes.
Early Legacys used the LB circuit. Eventually the LD spool was supplied. Not having measured hydraulic pressure with the Legacy gear in transit, I can’t say if the symmetric LD spool is really necessary. That being said, I do have LD spools and can easily turn this pump into the LD version.
An interesting side note. The LD spool can only be used with the higher speed .032 gear section. The reason is that the LD spool introduces a leak when operating (See attached). The higher flow gear section has enough margin to still build pressure despite the leak.
Postby Paul Miller » Mon Mar 08, 2021 10:38 pm
Chris, I'm studying that leak and trying to figure why it is in place?
Postby Chris Zavatson » Mon Mar 08, 2021 11:19 pm
Paul Miller wrote:Chris, I'm studying that leak and trying to figure why it is in place?
Not sure I follow the question.
The asymmetric spool keeps left and right sides completely separated. When bypass circuits were made for both directions a sneak path was introduced. The bore and spool have a finite gap between them. There is certainly a lot of resistance, but a seal can no longer be maintained. The only reason this still works is that we don’t need full pump pressure vs flow output.
Not sure if Parker was aware of it or not.
I tried one of these spools in a .019 pump and it was unable to achieve nominal operating pressures.
Postby Lex Thistlethwaite » Tue Mar 09, 2021 8:28 am
Chris, I’ll buy it. Look for my PM.
Lex Thistlethwaite
Postby Jeffrey Foltz » Fri Mar 12, 2021 10:54 pm
Chris - was this a one-of-a-kind thing or can you get more? Want one.
Jeffrey Foltz
235 building
Postby Chris Zavatson » Sat Mar 13, 2021 4:54 pm
Jeffrey Foltz wrote:Chris - was this a one-of-a-kind thing or can you get more? Want one.
Jeff,
First one is spoken for. More parts are on the way.
Will post when more are ready. I expect a week or two.
BTW, they can be assembled as an LB or an LD circuit.
Users browsing this forum: Chad Molyneaux, Jeffrey Foltz and 37 guests
