This is a new Parker clone pump with the LB back pressure relief circuit.
Equivalent to Parker number:108AMS32-CLB-3V-16-12
-.032 cipr gear section
-PRV - pressure relief valves - are set to up 1,600 psi, down 1,200 psi.
-TRVs -thermal relief valves- on both high and low sides
-12V
-T-fittings for pressure switches installed.
-Bench tested, holds pressure all day, both directions.
$500 plus shipping
