WTB Engine CHT & EGT probes Lyc 360
Postby Les Laidlaw » Sun Mar 21, 2021 9:03 am
I am installing a garmin G3X and need to find 4 CHT and 4 EGT engine probes for my lycoming 360 if you have any of these please let me know.
Thanks in advance,
Les
Reason: Improved title
Les Laidlaw
320look
Re: WTB Engine sprobe
Postby Paul Miller » Sun Mar 21, 2021 9:24 am
These are really inexpensive at Dynon, that's what I used on the G3X and Continental for CHT. Less expensive than anywhere else.
Re: WTB Engine CHT & EGT probes Lyc 360
Postby Erno Ovari » Sun Mar 21, 2021 2:21 pm
Les Laidlaw wrote:... and need to find 4 CHT and 4 EGT engine probes for my lycoming 360
Did Garmin stop selling those inexpensive gizmos or what is the problem ordering them from Garmin?
Erno Ovari
Location: FAA:U42 South valley - South of Salt Lake City, Utah
Postby Paul Miller » Sun Mar 21, 2021 3:26 pm
They were cheaper at Dynon.
Postby Les Laidlaw » Sun Mar 21, 2021 5:52 pm
Paul Miller, can the Dynon probes be used in the garmin g3x non touch setup? they are much cheaper and that would work great if they do?
Les Laidlaw
320look
Postby Steve Cantarutti » Sun Mar 21, 2021 5:58 pm
I don't know the Dynon probe pricing or quality, but have used GRT probes in a EI instrument. The GRT probes are working perfectly for me and appear to be good quality. Not sure if they would work in G3X but should if they take standard probes.
Lancair 235/340
RV-9A ( 2013 - 2016 )
Steve Cantarutti
titan
Postby Paul Miller » Sun Mar 21, 2021 6:11 pm
Les Laidlaw wrote:... can the Dynon probes be used in the garmin g3x non touch setup?
If you check the G3X installation manual you will see that Type J probes and wire are acceptable. AdamM suggested the Dynon probes when I was installing the G3X. There were half the price versus the Garmin parts. To read lots of posts about it you can do a search on Dynon+CHT+probes in the search box.
Postby Les Laidlaw » Sun Mar 21, 2021 11:01 pm
Thanks for the info I will check it out
Les Laidlaw
320look
Postby Paul Miller » Mon Mar 22, 2021 11:01 am
Looks like the Dynon price is still attractive. Note the Garmin product is type K. Dynon Type J. Both are acceptible and generically programmed into the G3X. Make sure to use the proper extension wire for the Type J or K. I bought that from Dynon also.
2021-03-22 08_58_51-GARMIN G3X CHT_EGT TYPE K THERMOCOUPLE 3_8-24 BAYONET _ Aircraft Spruce — Mozill.png
Users browsing this forum: admin, Bing [Bot] and 28 guests
