WTS - Legacy spinner/backplate
Postby Jim Barnette » Mon Apr 26, 2021 9:19 am
If you need a spinner and back plate, I have one.
price : [requested from Jim]
Jim Barnette
Re: WTS - Legacy spinner/backplate
Postby Larry Jessen » Tue Apr 27, 2021 10:24 pm
Jim, I talked to Paul today just saw your post. I need a Hartzell 3 blade spinner with 16” backing plate. What do you have? Thanks Larry Jessen
Larry Jessen
Building IV-P
Postby admin » Tue Apr 27, 2021 11:23 pm
[Larry, I was going to contact you on this. The Legacy spinner is 14 inches and aluminum (my mistake) and I spoke to Maurits who suggested you will want the composite spinner if Lancair has one or possibly someone here. So, you should post a WTB ad for your 3-blade Hartzell prop but I'm told the MT spinner can fit also.
I think that's the quickest way to get your spinner, a WTB ad and put your prop type. Separately, you should tell people what you're doing because when it gets done, it could be way cool and an option for others, particularly the prop and engine. I'll move this once you place the WTB.
A raw spinner and backplate would require work. A used one might fit your prop with little work. Pictures would help and Jim should put pictures of his spinner/backplate here also.]
Trouble with photos or login or passwords or avatars or anything, you can PM or email or simply call. you can use text and skype also.
USA 406-873-8311
Canada 587-432-7536
Users browsing this forum: Adam Molny, admin, Roman Shkvarok and 24 guests
