FS: 2006 Lancair Super ES (TAT TN, G3X, GTN 750/650, 930)
Postby Neal Schwartz » Fri May 28, 2021 7:17 pm
Latitude Aviation is proud to bring to market N707LH, which is spectacular 2006 Lancair Super ES with no known damage history. N707LH is owned by a LancairTalk member and it is based in Atlanta, GA. The owner bought the plane from the builder so it is a 2-owner aircraft.
N707LH's IO-550-N engine was upgraded in 2014 with Tornado Alley's turbonormalizing system and it also has a 4 blade MT propeller. The performance is incredible due to the TN system. The owner reports 190 knots TAS at 9,000 feet on 17gph and said that the TAS will increase to 206 to 210 knots through 17,000 feet (with a constant fuel flow of course). Those are pretty awesome numbers when compared to the TN SR22's and A36's that I've flown.
In addition the TN system, the plane has some great upgrades such as the Kelly Thermawing heated deice system, built-in Mountain High oxygen system, Precise Flight speed brakes, turboGAMIjectors, LED and HID lights, and dual alternators/batteries. And while there are 4 seats in the normal configuration, you can fold the rear 2 seats down which provides an incredible amount of space for bags and other associated items.
All of that said, one of the most notable aspects of the plane is the panel of course. It comes with dual Garmin G3X screens, a G3X autopilot, Garmin GTN 750/650 combination, Garmin G5 standby PFD, XM weather, ADS-B In traffic/weather, dual AOA's (Garmin and Advanced Flight Systems) and an EDM 930 engine management system. One of the cooler upgrades to the avionics is the Astronix Max-Vis EVS system. This system is not only helpful for something like an approach at night but it is also very helpful for an engine out scenario at night. And the owner told me that it has also benefits him when flying at night and flying around puffy clouds or build-up's.
This plane is incredibly clean and the owner is meticulous. Every detail has been thought of and cosmetically it is in fantastic shape as well. The more I learn about the Lancair Super ES' in general as well as this particular build the more impressed I get. It is a fantastic experimental alternative to the certified world and represents a tremendous value in my view. Below are detailed specs for the plane including Dropbox links to the logbooks and photo gallery. I have also attached some photos to this post as well. Please email or call anytime to discuss N707LH. Thank you!
-Neal
N707LH
Serial # ES104
Price: $349,000 USD
Contact:
Neal Schwartz
Latitude Aviation LLC
914.625.5776
neal.schwartz@gmail.com
Airframe: 1219 TT
Engine: 1219 SNEW / 744 STOH – Continental TNIO-550-N
Propeller: 594 SNEW – MT Propeller MTV-14-D 4-blade propeller (Factory new 4/2016)
Max Gross Takeoff Weight: 3550 pounds
Basic Empty Weight: 2370 pounds
Useful Load: 1180 pounds
Usable Fuel Capacity: 94 gallons
Empty CG: 95.04 inches
General:
• Aircraft hangared at Griffin-Spalding County Airport (6A2) in Atlanta, GA
• No known damage history
• Always US-based and hangered
• Tornado Alley Turbo, Inc. turbonormalizing system
• Complete logbooks and high-resolution photo gallery available by clicking here: https://www.dropbox.com/sh/ar3fm882cdvn ... BxEla?dl=0
• All FAA AD’s in compliance
• Annual condition inspection due 4/2022
• IFR certification due 5/2023
• ELT battery due 4/2024
• 5/2021 compressions were 76/72/72/77/76/78
Avionics:
• Dual Garmin G3X 10.6” Touch PFD/MFD (with SVT)
• Garmin G3X autopilot (with GMC 305 autopilot controller, yaw damper, ESP-X/Level capability, and full 3-axis trim control)
• Garmin GTN 750 #1 WAAS GPS/Nav/Comm
• Garmin GTN 650 #2 WAAS GPS/Nav/Comm
• Garmin G5 standby PFD (with back-up battery)
• Garmin GI 106A CDI/GS
• Garmin GTX 23ES remote ADS-B In/Out transponder (displays ADS-B traffic and weather)
• Garmin GDL 51R XM receiver (displays XM weather)
• Garmin GMA 35 remote audio panel (controlled through the GTN 750)
• Garmin Connext wireless technology (via the Garmin G3X Touch)
• JPI EDM 930 color engine management system
• Astronics Max-Viz Enhanced Vision System (EVS)
• Garmin G3X integrated Angle of Attack (AOA) indicator
• Advanced Flight Systems Angle of Attack (AOA) indicator
• Back-up altimeter
• CO Guardian 353-101 CO2 detector (integrated with Garmin G3X displays)
• Artex 406mhz ELT
• Davtron M800 digital chronometer
• Dual Davtron M450 volt meters
• Avionics wired with Approach Fast-Stack wiring system
Additional Equipment:
• Kelly Thermawing deice system
• Electrically heated propeller deice system
• Mountain High built-in dual bottle oxygen system
• Precise Flight speed brakes
• turboGAMIjectors (customized tuned fuel injectors)
• Dual 75 watt XeVision HID landing lights
• LED taxi light
• LED nav/position lights
• LED ice and position/strobe lights
• Rosen sun visors
• Dual alternators/batteries
• Electric inflatable door seal
• Retractable step
Miscellaneous Maintenance:
• New PlanePower alternator on rear of engine at starter adapter 4/2021
• Thermawing alternator moved to front position 4/2021
• All new tires 4/2021
• New brake pads 4/2021
• New electro/pneumatic door seal 4/2021
• New exhaust 10/2019
• 6 new fine wire spark plugs 10/2019
• Dynamically balance propeller 7/2019
• New wastegate 12/2018
• Overhaul starter adapter 12/2018
• Overhaul magnetos 12/2018
• 6 new fine wire spark plugs 8/2017
• Replace all 6 cylinders with overhauled RAM Nickel cylinders 4/2015
• New Tornado Alley turbonormalizer system 8/2014
• Overhaul engine-driven fuel pump 8/2014
• New turbochargers 8/2014
• New Thermawing alternator 5/2008
Exterior:
• White with Bright Blue Metallic, Navy Blue Metallic, and Light Blue Metallic stripes
Interior:
• Tan leather
• Seats, side panels, and cockpit trim recovered in leather in 2015
• All 4 seats have seat heaters (but relays/switches not yet installed so they aren’t functional yet)
Neal Schwartz
Aircraft Sales
Re: FS: 2006 Lancair Super ES (TAT TN, G3X, GTN 750/650, 930
Postby Neal Schwartz » Fri May 28, 2021 7:21 pm
More pictures.
-Neal
Neal Schwartz
Aircraft Sales
Postby Neal Schwartz » Fri May 28, 2021 7:24 pm
More pictures.
-Neal
Neal Schwartz
Aircraft Sales
Users browsing this forum: Daniel Cahill, Gary Weeks, Jeff Edison and 30 guests
