This Lancair 360 kit is a terrific value. It was started in 1994 and the Seller is the 2nd owner. The wings have been closed and pressure tested. There are Princeton probes in 2 wing tanks and Skysports gauge and probe in the header tank. A Pillar Point automatic fuel transfer system is included. A Trutrak Sorcerer autopilot Tray and connectors is installed and there is a Digiflight II VSG 2 axis head with vertical steering, altitude hold and GPS steering included plus 2 Trutrak servos installed
The Crossflow engine is available for sale separately.
The electric MT-Propeller 3-bladed constant speed prop comes with the plane and can be converted to hydraulic C/S at MT USA if required. The propeller has 1 hour of runtime and includes the controller and spinner as pictured.
All major components have been completed elevator, rudder, ailerons with mac trim servo and tab. The elevator also has mac servo trim tab. Flaps completed but hinges are cleco'd and need rivets,
The forward hinging canopy is completed and has the protective film attached. The central locking system is completed. The dual adjustable rudder pedals are completed. A long engine mount and Chris Zavatson custom cowling also are included. The kit is 90% completed and is a very good build. Below is a summary of what is included.
- Forward hinging canopy with central lock system installed
- Pillar Point automatic fuel transfer system installed
- Long Engine Mount
- Original tail, not MK II tail.
- Custom Cowling by Chris Zavatson
- New Oildyne hydraulic pump with High and Low gauges, Low & High pressure sensors installed
- Flap Relays installed
- Landing gear relays installed
- Whelan 3 strobe system installed wingtips and on rudder.
- MT 3 bladed propeller electric constant speed MTV-18-/175-59d
- Trutrak yaw damper installed
- Trutrak 2.25 inch backup electric attitude indicator installed
- Dual 12V Buss 2 Odyssey batteries installed
- Ameriking ELT
- Infinity dual stick grips wired with speed controller board installed
- 2 GRT HX 6 inch MFD's installed
- GRT EIS 4000 engine monitor system installed
- GRT Satellite weather module installed
- Mac aileron and rudder led trim indicators installed
- Skysports header fuel gauge and probe installed
- Trutrak Sorcerer autopilot Tray and connectors installed
- Digiflight II VSG 2 axis head with vertical steering, altitude hold and GPS steering included.
- 2 Trutrak servos installed
- 2 air vents mounted in the panel
- Throttle cable installed
- 2.25 inch backup airspeed, vertical speed and altimeter
- Compass installed
- Landing gear switch and lights
- AOA PRO angle of attack system sensors are mounted in the wing installed
- Many switches and circuit breakers installed all aircraft grade
- 2 TK5 landing gear shocks new in the box not installed
- 2 Airlite landing gear lights new in he box not installed
- Grove high performance brakes new in the box not installed
- 2 Manuals and blue prints and many building pictures and build logs.
- engine available separately
- located NJ, USA
- Will help ship and pack. Ships worldwide
Call me for questions or to get information on purchasing this kit.
