DO NOT CALL A BROKER IF YOU WANT INSURANCE. DO NOT CALL GALLAGHER before speaking with LancairTalk or you may not be able to acquire this Lancair.
Remember that Lancair airframes don't age or fatigue or corrode. If you take care of the consumables this airplane can last forever. The owner wishes to find this Lancair a new home. Are you the new owner of a well-built 235 with lots of features for a tall pilot?
Lancair N10CF Overview
Engine
- Don George High Compression O-290-D2 with O-320 Crankshaft
- Rated 140 HP at 2800 rpm (145 HP for 5 minutes)
- Oil Pan Heater
- Basic VFR/Day panel/Avionics
- Dynon D-6 EFIS
- AFS Sport AoA
- Garmin GTR-200B radio with intercom and Bluetooth. Bluetooth connects to iPad
- Garmin GDL-82 – ADS-B (out)
- Stratus 3 ADS-B (in)
- Broadband ADS-B/transponder antenna
- Carburetor temperature gauge
- Davtron 811B digital clock
- Davtron 5-in-1 gauge Volts/OAT/Pressure Alt/Density Alt
- JPI EDM-700 Graphic Engine Monitor with fuel flow
- 406 Mhz ELT with new battery
- Digital Tachometer
- Ventral Fin and Extended Rudder
- Three Rudder Hinges instead of Two
- Five Control Surface Hinge screws instead of Three
- Custom Airbox with K&N filter
- Custom Crossover 4 into 2 Exhaust
- Hydraulic Pump with backpressure circuit
- No horizontal holes in longerons for structural integrity
- Carbon fiber longeron beef-up
- Used fuses rather than circuit breakers
- “Lifetime” Teflon/SS overbraid hoses throughout
- Cabin Air NACA vent above header tank rather than on side for structural integrity
- Reclined seat back for tall pilot/passenger
- Minimal Interior. You can customize for smaller pilots or leave as-is for larger pilots
- Configured CG for heavy pilot/passenger (240 lbs. minimum)
- Comm antenna built into vertical stabilizer
- Roll trim servo in left aileron
- 1” sound insulation on firewall interior
- No rudder/brake pedals on passenger side.
- Added Halon spray bar in the engine compartment
- All service bulletins incorporated
- Partial gear-up landing
- Wooden prop struck runway end light
- Original Logbooks: Engine, Airframe (2), Prop (2).
- Original Builder Manual
- Original Build Log
- Construction Photos
- Jacks
- Bead Breaker
