PRICE IS 399K MAKE OFFER!
Over 600k to replicate! If you could find a kit!
Stunning Legacy for Sale - I bought a jet and wife wants this gone, this is the most fun airplane I have ever flown - my loss - your gain!
Ring me up for more detail - 667.458.9312
Built at Lancair Factory and delivered in 2020 with new engine - 150hrs approximately - I will be going to Reno this year and racing the plane (with a pro pilot)
FRESH INSPECTION WITH NEW OIL CHANGES AND BREAK IN DONE
System32 EFII - https://www.flyefii.com/products/efii-systems/
Push button start - no mags or mechanical fuel pump
No hot or cold starting issues
No damage history and all AD's checked
Gear mods done
New brakes and tires
Plane is completely sorted
Plane was completely gone through at Flight Metrics in Redmond Oregon
Custom paint design by Plane Schemer
Perfect airplane with following:
Precise Flight Speed Brakes
Beringer Main Wheel Brakes
Pilot/co-pilot adjustable rudder pedals & brakes
Inflatable canopy seal
Elevator and rudder electric trim
Titanium wing bolts
Redesigned nose wheel strut
Canopy cover
Cowl Plugs
Wing mats w/Legacy logo and N-number
Lancair anodized aluminum tow bar
Fire Extinguisher
New batteries just installed Lithium Ion
02 will be added shortly
Engine specifications:
Continental IO-550-N
310 horsepower w/ ram air
Barracuda Dual EFII system - Electronic Fuel Injection and Ignition w/ push button start*
Dual Batteries
Dual Alternators
*Electronic Fuel Injection and Ignition:
Computerized engine management incorporating a fully mapped fuel curve and ignition timing curve
Fully redundant – dual engine computers and sensors
Push button start
Automatic mixture control
No mags and no mechanical fuel pump
No hot or cold starts – just push the button
Less weight
Less maintenance
Increases engine performance up to 10%
Fuel savings – always have exactly the right mixture
Aircraft Performance:
Cruise 235 kts (270 MPH) @ 15 gph
Climb 2200 fpm
Fuel capacity 64 gals
Avionics:
Cumulus Avionics Panel - includes:
Dual Garmin G3X Touch 10.6" displays with XM receiver
Dual Garmin GSU-25 ADAHRS units
Garmin GEA-24 engine indication system (EIS) with sensors
GMC-307 3 axis Autopilot with yaw damper
Heated Pitot / AOA probe
Garmin GMA-245 Remote Audio Panel
Garmin GTN-750 GPS/Nav/Com
Garmin GTR-20 Remote Com
Garmin GTX-45 remote Transponder with ADS-B In & Out
406 mhz ELT
CO detector
custom engraved instrument panel
LED Glareshield light strip
all antennas, switches, power conditioners and jacks
NOTE - Next oil change will do an oil analysis - borescope and compressions are within specs
Ring my cell if your interested and please only serious inquires - 667.458.9312
