- Lancair IV-P with Garrett TPE331-6 840 hp turbine engine
- XXX hours total time airframe since new to be uipdated
- Empty Weight: 2602 lbs.
- Gross Weight: 4400 lbs.
- Total Fuel Capacity: 146 US Gal.
Engine
- TSO: 4266.2
- CSO: 4491
- First stage turbine rotor TSN: 1943.1 CSN:1575 Time remaining: 4125 cycles
- Second Stage turbine rotor TSN: 3063.4 CSN: 4300 Time remaining:1100 cycles
- Third stage turbine rotor TSN: 2138.0 CSN:2282 Time remaining: 1318 cycles
- AD 2016-18-17 second stage impeller limited to 11,500 cycles since November 4, 2016
Avionics
- Garmin G900X Dual screen EFIS
- Garmin G3X GDU470 Backup EFIS
- Vertical Power VP200 Full Aircraft Management System
- TruTrak Sorcerer Autopilot 2 axis
- VR Avionics Engine Monitor with Garrett engine auto start system
- Cabin Pressure Differential Indicator (UMA)
- Cabin Pressure Rate Controller (Dukes)
- Artex 406/121.5 ELT with GPS positioning
- ADSB
Features
- Pressurized cabin
- Cabin Air Conditioning with cabin temperature monitoring
- Firewall forward fire suppression system
- Full aircraft de-ice system (prop, wing, horizontal and vertical leading edges)
- Brakes are dual caliper on each main wheel
- Emergency O2 with Quick donning masks
- Fire extinguisher in cabin
- Front seats are adjustable front to back and reclining
- Retractable step for easier access to the cabin
