WTB: Vision Microsystems Manifold Pressure Transducer
Postby Jake Wolfe » Sun May 19, 2024 8:21 pm
Looking for a Vision Microsystems P/N 3010006 Manifold Pressure Transducer, 30 PSI version for turbo engine.
Jake Wolfe
Re: WTB: Vision Microsystems Manifold Pressure Transducer
Postby Paul Miller » Mon May 20, 2024 7:45 pm
Jake, can you see a p.n? The VAF posts show it as a 15 psi abs pressure sensor. lots of similars on digikey but not much in stock. If you had a generic p/n it would help. I believe it looks like this but I don't know the voltage specs of your device.
https://www.digikey.com/en/products/detail/amphenol-all-sensors-corporation/15-PSI-A-HGRADE-MV/503171
Postby Jake Wolfe » Mon May 20, 2024 9:22 pm
15psi is for naturally aspirated engines. I'm probably going to have to tear it down and try to source a new sensor. Reggie used to fix these but is gone, was hoping someone just had a working one out of a panel upgrade.
Jake Wolfe
Postby Corey Howatt » Wed May 22, 2024 10:27 pm
I have a full system i just pulled off my TSIO-550. Not sure of the P/N, but I can look when I get home if you're interested.
Corey Howatt
