320 gear pump failed.
Re: 320 gear pump failed.
Postby Chris Zavatson » Sat Mar 01, 2025 9:34 am
One guess is that the gear section seized which then broke the coupling. If you pull the motor off you’ll be able to check that.
Yours is one of the earliest pumps. Those motors of that vintage have been failing from either worn bearings or shorted windings. The casting for the adapter did not yet have the tabs for top mounted reservoirs. It will also not have the LB back pressure relief circuit.
The smaller metal reservoir can be transferred to new pumps as long as the gear section was drilled for the mounting screw.
Postby admin » Sat Mar 01, 2025 2:59 pm
Paul N needs a pump with the LB circuit IMO. The early pumps did not have this circuit which allows for double acting work to be done. This missing circuit was probably not recognized early by the development team and we still see other landing gear on non-Lancair models coming hear for help. Chris Z, is this your view also? Replace the pump?
Postby Paul Nafziger » Sat Mar 01, 2025 3:52 pm
Everything turns freely. Can't see any damage. Who would you recommend I buy a new pump from and what model?
Paul Nafziger
Postby John Cooper » Sat Mar 01, 2025 5:00 pm
As others have said, do NOT attempt to by a new pump from Oildyne. They won't sell to Lancair owners, and actually have a list of them. Pricks.
WARNING! Incorrect design and/or fabrication of aircraft and/or components may result in injury or death. Information presented in this post is based on my opinion only - Reader has sole responsibility for determining accuracy or suitability for use.
John Cooper
rank-235
Postby Chris Zavatson » Sat Mar 01, 2025 5:24 pm
Paul N.
Next on the hit list: broken pressure relief valve or broken gear pump section.
New pumps are available here for $850. (Need to add a blurb in the owner supplied parts section). This would be the latest configuration with the LB circuit, the newer pump, larger reservoir etc. (the old reservoir can be reused)
Postby Paul Nafziger » Sat Mar 01, 2025 5:30 pm
Chris Z
Can I ship it to you to have it checked out?
Paul Nafziger
Postby Chris Zavatson » Sat Mar 01, 2025 11:17 pm
Paul Nafziger wrote:Chris Z
Send it. will PM address
Postby Paul Nafziger » Sun Mar 02, 2025 12:09 am
Will do. Need to remember to post the findings for the viewers edification.
Paul Nafziger
Previous
Users browsing this forum: No registered users and 140 guests
