WTB Right MLG inboard bearing block & bearing
Postby Jeff Nielsen » Fri Nov 15, 2024 9:50 pm
I have discovered my somewhat high-time Lancair (1500+ hrs) has failed its right main landing gear bearing and bearing block, probably due to lack of lubrication, as no lubrication serviceability was designed into this moving part. May anyone have a source?
Reason: ed for clarity and sp and moved to WTB
Jeff Nielsen
Re: WTB Right MLG inboard bearing block & bearing
Postby admin » Sat Nov 16, 2024 3:52 pm
please post pictures of the damage and parts and the model of your Lancair?
Postby Jeff Nielsen » Sat Nov 16, 2024 11:29 pm
The plane is a Lancair IV-P. Posting an image of the inboard MLG bearing block while it is still assembled on the plane would not show the damage. It remains assembled and I fly it regularly. It is no small project to replace this bearing and bearing block. I had hoped to procure another bearing block prior to disassembling the plane to replace the damaged bearing block. I am agreeable to providing images of the damaged parts when they are disassembled…Jeff.
Jeff Nielsen
Postby admin » Sat Nov 16, 2024 11:44 pm
You don't have to post anything. It was simply to help people understand the issue, location and other surrounding areas. Not everyone has a IV-P. We use this site for education and support and pictures are one way of helping others understand and learn. Hopefully you get a solution.
Users browsing this forum: No registered users and 147 guests
