Vertical Power VP-200 CU
Postby Kevin Johnson » Sun Feb 01, 2026 9:23 pm
I'm looking for a control unit for a VP-200. I know many have updated to the newer units and may have a used CU laying around. I made the mistake of installing the battery backwards.
Let me know if you have one.
Thanks
Kevin Johnson
enthusiast
Re: Vertical Power VP-200 CU
Postby Erno Ovari » Mon Feb 02, 2026 10:18 am
I found it very easy to work with the Vertical Power people. I would just call them, explain the problem, and plan to send your unit in. They will fix it.
Erno Ovari
Location: KSVR (South valley) - South of Salt Lake City, Utah
Postby Kevin Johnson » Mon Feb 02, 2026 10:28 am
I'll give it a try.
Kevin Johnson
enthusiast
Postby Kevin Johnson » Tue Feb 03, 2026 9:00 pm
I contacted them and basically they said I needed to purchase a Vpx sport or pro. No help at all.
So if someone here has one for sale, I'd appreciate a reply.
Thanks
Kevin Johnson
enthusiast
Postby LancairTalk Sales » Wed Feb 04, 2026 3:14 pm
That's because it is a different company than the -200 company. The new company never supported the previous company's products because of the hardware failures. That's why anyone buying a new VPX system should use AircraftSpruce as they will (generally) support any of the products they sell.
Lancairtalk is a dealer for ACS and if anyone on this website has a decent order above $250 we can usually save some money and for larger orders we can save quite a bit and still support the website.
Postby Kevin Johnson » Wed Feb 04, 2026 4:50 pm
I understand about Vertical Power being bought out and that the VP-200 is no longer supported. Just trying to get it repaired without changing out the entire system,
Thanks for your help.
Kevin Johnson
enthusiast
Postby Jon Hadlich » Tue Feb 10, 2026 10:15 am
Yep, no support for the vp-200. You'll have to find a used unit in the wild.They're out there...Try the van site as well. Someone will have on sitting on a shelf. Same as Chelton. Good luck
Jon and Fred Hadlich
AI Systems
KRDM
Maintenance and avionics specializing in all Lancair models
Jon Hadlich
hadlich
Postby admin » Tue Feb 10, 2026 12:48 pm
I sent the OP parts which were removed as a VP-200 system for the VP-X but OP informed me they are not VP-200 parts (some had vp-50 stickers on them) so they were returned. The parts are still available to someone who might need them.
Postby Kevin Johnson » Tue Feb 10, 2026 3:53 pm
Yea, the VP CU looks alike on both. But the VP-200 has a Display Unit where the VP-50 doesn't.
Kevin Johnson
enthusiast
Users browsing this forum: No registered users and 126 guests
