LT-WTS: Accumulators for Lancair IV-X
Postby LancairTalk Sales » Wed Apr 10, 2024 10:21 pm
We have new Hydac accumulators for the IV series. These are 3000 psi, 0.5L volume, with the cold temperature bladder material (good to -40) which is best suited for high altitude temperatures and winter ops.
Hydac makes the Parker units so that's why they look similar. See pictures below. The pressures for preset of the bladder can be discussed here also. There actually is some science to the preset and the pressure depends on how the accumulator is used.
Contact Sales for current pricing and availability.
previous unit (used) as removed.
technical drawing
SBO Series.pdf
specifications
(169.21 KiB) Downloaded 1858 times
New units ready to ship
New unit ready to ship
Reason: updated some notes
Re: WTS: Accumulators for Lancair IV-X
Postby Tom Nalevanko » Thu Apr 11, 2024 11:58 am
Again, very nice to see availability.
Best,
Tom
Tom Nalevanko
Postby LancairTalk Sales » Thu May 09, 2024 9:15 am
Three units remaining for Lancair owners who want an accumulator. These are brand new with the low temperature membrane as recommended by the manufacturer for coldest operations. Rated 3000 psi @ 250F. capacity 0.5L.
These are bladder-type units. There are other units that are longer and utilize and piston and spring.
In the past, there have been questions about the pre-charge pressure. There is actually a set of equations to use based on the intended use of the accumulator. Is it storing a safety charge or preventing movement in a lift device or providing buffer for surging or providing spare hydraulic pressure.
If you want a spare or replacement unit please reply or PM or email. Typical restock times seem to be about 5-6 months so don't get caught. If you have acquired a Lancair with an accumulator be sure to ask on LancairTalk how to check the capacity and operation tests. Some of these units could be 24 years old perhaps in Lancairs so...
Postby David Skinner » Wed May 15, 2024 9:57 pm
I received my new accumulator today from the batch discussed above. It looks like a good match for the original.
Original Accumulator markings
MAWP 3000 PSI AT 180 F MDMT 5 F MADE IN GERMANY 05/94
HYDAC 0 210 9449/113/ VOLUME 30 CU.IN. PO PSI SN 060864
New Accumulator markings
MAWP 3000 PSI AT 250 F MDMT -20 F MADE IN USA 04/24
HYDAC 2109449/113 VOLUME 30 CU.IN. SN A 2977641
Thanks Paul and Ed
I plan to charge it to 600psi and install it this weekend. Does anyone have ideas for avoiding more oil in my face when I uncap the line and connect it to the accumulator?
The red one is the original and the black one is the new one
David Skinner
Re: LT-WTS: Accumulators for Lancair IV-X
Postby LancairTalk Sales » Thu Oct 24, 2024 6:44 pm
Contact Sales@lancairtalk.net for current price and availability.
Sales of this part help run this website.
Return to LancairTalk Parts/Services
