Postby Louis Gabriel » Fri Jun 24, 2016 4:34 pm
Paul Miller wrote:I don't know if a metal enclosure is a better choice (for fire protection)
Thanks for the kind words Paul! Just so you know, the ABS enclosure is UL94V-0 rated (self-extinguishing). I wanted to minimize any possibility of a short while retaining good fire retardant properties.
Louis
Postby Paul Miller » Fri Jun 24, 2016 4:40 pm
OK Louis, I sort of knew posting that comment was risky given the thought that went into the device. But, my issue is answered and to be added to the spec sheet. thanks for the wonderful design. I will jack the plane up soon and test the connections then test the gear operations with some video.
Postby Mike Wynn » Fri Jul 01, 2016 4:39 pm
Please reply with your contact method/physical address and payment preferred for one (1) of your Hydraulic Pump Controllers. I'd be glad to snail-mail a check or use PayPal, as you like.
Thanks for being there with this improvement.
Mike Wynn
Moab, UT
435-259-8960
Mike Wynn
320360b
Postby Chris Zavatson » Fri Jul 01, 2016 11:44 pm
Mike Wynn wrote:Hi Chris,
Mike Wynn
Moab, UT
435-259-8960
Mike,
I sent an email with details.
Thanks,
Chris
Postby Jon Hults » Sun Jul 17, 2016 2:14 pm
Looks great! I need one for sure. Any issues with having it forward of the firewall?
Thanks,
Jon
Jon Hults
Temecula, CA
Legacy N222BZ
(...under construction!)
Jon Hults
L2k-building
Postby Chris Zavatson » Sun Jul 17, 2016 11:34 pm
Jon Hults wrote:Any issues with having it forward of the firewall?
Jon,
The original intent was that the controller would be mounted in the cabin close to the hydraulic pump. Most pumps will be in the cabin somewhere. As a result, not all components are rated to 200+ degF that can be encountered in the engine compartment.
All boards are screened at 140F.
Postby Jon Hults » Mon Jul 18, 2016 6:49 am
I was afraid of that. Yes, I had planned to put it next to the hyd pump and battery, but those are going to be up in the engine compartment too. Back to the drawing board.....
Thanks,
Jon
Jon Hults
Temecula, CA
Legacy N222BZ
Jon Hults
L2k-building
Postby Chris Zavatson » Mon Jul 18, 2016 7:33 am
Jon,
-just an FYI.
The Parker hydraulic pump itself is rated to 140 deg F.The data sheet advises to consult Parker if you want to go above that.
Postby Dennis Johnson » Mon Jul 18, 2016 7:53 am
Hi Jon,
You must have an interesting build to be able to move the hydraulic pump and battery to the forward side of the firewall and not have a center of gravity problem.
Dennis
Dennis Johnson
Postby Eric Miller » Mon Jul 18, 2016 8:28 am
Dennis Johnson wrote:You must have an interesting build to be able to move the hydraulic pump and battery to the forward side of the firewall and not have a center of gravity problem.
Tail wheel mod?!?! :D
Eric
N9BF '95 IO-320 Mk I #771
Eric Miller
Users browsing this forum: Bing [Bot], Steve Alderman and 30 guests
