I am looking for a Lancair Legacy panel that is straight across (no hump above the radio stacks), similar to the one in the picture below. It does not need to be carbon. I am also looking for the dust cover.
One option is you could make your own. The templates to cut and design offline are easily available here and the avionics are cheaper to buy and the harness can be made offline also or you can do that yourself. That way you control the product and cost and, most importantly, the time to completion. For example, you can pull the Legacy panel templates online here and the software from frontpanelexpress.com and design your layout. Ask kitloom harness to build the harness. Get your avionics here and we give you InstallSmart packages to install everything except the LRUs for a fraction of the total cost. When you are ready to power up, make the final payment and take delivery of the LRUs and complete the panel. We also hold the price while you build and nobody else does that for Lancair builders.Jason Rouault wrote:I am looking for a Lancair Legacy panel that is straight across (no hump above the radio stacks)
Users browsing this forum: No registered users and 11 guests
