Postby Brett Rhode » Sat Dec 29, 2018 2:03 pm
I would like one also - 28v.
Please send payment info.
Thanks!
Brett Rhode
Postby Chris Zavatson » Sun Dec 30, 2018 3:50 pm
Brett Rhode wrote:Chris,
Thanks!
Brett,
We are awaiting MOSFETs to make more boards. Unfortunately we are competing for supply. There appears to be an ongoing worldwide shortage. We've been told Mid-January
http://www.advancedmp.com/news/mosfet-component-shortage-2019
You are on the list.
Postby Brett Rhode » Sun Dec 30, 2018 11:15 pm
Chris - thanks for the fast response.
Please keep me posted.
Brett Rhode
Postby Keith Scrivens » Tue Jan 01, 2019 8:48 am
Hi Chris could you put me on list for Hyd pump controller should be at that stage by the time you can produce thanks
Keith Scrivens
Postby Art Jensen » Wed Jan 02, 2019 2:33 pm
FYI to all;
I was the lucky bidder on one of these controllers at the LOBO event in Santa Fe. The controller was easy to install per the instructions and has worked flawlessly well over a year now in my Legacy. I don’t recall for sure now but also reduced the weight of the plane by 12-15 ounces. They all get heavier with age so this mod helps reverse that trend.
Art Jensen
Postby Phil Sciuk » Sun Mar 10, 2019 11:25 pm
For anyone using this controller combined with the adjustable pressure switches in a Legacy could you confirm the settings you are using for the high and low pressure switches.
Postby Paul Miller » Sun Mar 10, 2019 11:40 pm
Phil, are you sure the high pressure and low are in the right outlets?
Postby Phil Sciuk » Sun Mar 10, 2019 11:56 pm
Paul Miller wrote:Phil, are you sure the high pressure and low are in the right outlets?
The photos are not from my installation. I’ve purchased the controller and pressure switches and planning to install them once I determine how to set the pressure switches.
Postby Dino Quaresimin » Tue Jul 16, 2019 8:14 am
Hi Chris,
Do you also have a solid state controller for replacement of
1. battery relay
2. engine start relay
3. cross-tie relay
Or do you know of a good one on the market
Thank you
Dino
Dino Quaresimin
Postby Tom McNerney » Mon Jul 22, 2019 10:37 am
Dino Quaresimin wrote:Hi Chris,
1. battery relay
3. cross-tie relay
Thank you
Dino
I'm not 100% sold on this idea, but there is this from Vertical Power if you have a rather simple electrical system:
http://verticalpower.com/index.php/products/pps
Tom McNerney
PreviousNext
Users browsing this forum: Matt Candelaria and 70 guests
