WTS High Performance Calipers for 360 Outback Gear
Re: WTS High Performance Calipers for 360 Outback Gear
Postby Roger Iverin » Sat Jun 20, 2020 2:51 pm
Are these cast in steel? And steel pistons?
How much are the weigh increase actually, i believe its a very good trade but just curious.
Best regards
Roger
Roger Iverin
N360DF in progress.
"Likes to improve stuff"
Roger Iverin
Postby Chris Zavatson » Mon Jun 22, 2020 12:56 am
Roger Iverin wrote:Are these cast in steel? And steel pistons?
Best regards
Roger
Roger,
Both the housing and pistons are aluminum.
The original Matco single piston caliper is 546g. The new triple piston caliper is 1015g.
Postby Roger Iverin » Tue Jun 23, 2020 1:44 pm
Thanks Chris,
Was just little confused since you mentioned titanium.
I did not think its was lighter. But I assume you would redesign the dimension with titanium
and get the same strange and lower weight.
Roger
Roger Iverin
N360DF in progress.
Roger Iverin
Postby Chris Zavatson » Tue Jun 23, 2020 2:20 pm
Roger Iverin wrote:Thanks Chris,
Roger
Hadn’t really considered titanium at the time. It would cost a fortune, for sure. Just for kicks, I looked up the cost of a bar on McMaster 1”x 3/4”x12”. $227. There are probably cheaper sources, but you get the idea :wink:
Postby Roger Iverin » Tue Jun 23, 2020 6:55 pm
Quite intresting actually!
:pop:
Roger Iverin
N360DF in progress.
Roger Iverin
Previous
Users browsing this forum: Bing [Bot] and 31 guests
