WTS: Landing Gear Audio Warning Module
Postby Nidal Robb » Fri Mar 15, 2019 7:43 pm
This module does one thing; callout "Check Landing Gear" if the airspeed reached a set point while the Gear Switch is still indicating UP position.
“Check Landing Gear” audio alert.
- Pilot set speed
- Configuration option to only arm the alert when reaching 5 knots more than the set speed.
- Can be configured to alert during take off as a functional test of the system on each take off
- Option to hear: “Gear Warning Active” when reaching the Set Speed
$185
EDIT:
Coupon code expired. Thanks for those who supported the development & the forum.
I am keeping the $10 for the forum. Any purchase for a Lancair airplane gets this forum a $10 donation/unit.
https://www.enginebridge.com/product/ge ... ng_module/
http://EngineBridge.com
- Audio & Vocal Alert System
- Height Call out down to 0 feet.
- Pump Pressure Controller
- Speed Switch and Auto-Extend
- PMag Controller
- PM/Email about showing your PMags on your Glass Panel!
Nidal Robb
Re: WTS: Landing Gear Audio Warning Module
Postby Phil Sciuk » Fri Mar 15, 2019 9:07 pm
could this unit work with an amphib
Postby Nidal Robb » Fri Mar 15, 2019 11:48 pm
Phil Sciuk wrote:could this unit work with an amphib
Is it equipped with a retractable gear?
This module is not similar to the Landing Height Controller which comes with a Laser unit to measure actual height above grounds. This module gets the airspeed from Pitot/Static lines and monitors the Gear Switch Up side. So if the airplane has such a Gear Switch then this module will work and should alert if speed reached the Set Speed while that wire still have 12v indicating the Switch still in the UP position.
- PMag Controller
Nidal Robb
Postby J Wales » Mon Mar 18, 2019 9:23 pm
Nidal,
Remember that the amphib (assuming its a water landing) has just the opposite desire that a non-amphib retract has. With a water landing the annunciation would be “check gear retracted”! Bad things happen if the gear is down for a water landing in most or all amphibs.
J Wales
Postby Nidal Robb » Mon Mar 18, 2019 9:35 pm
J Wales wrote:Nidal,
Sure.
The actual call is “Check Landing Gear” and no problem in changing it to even own language if desired.
And in this case, they would wire the Gear Switch down position to the PIN, so now the callout will be made when a it sees the Landing Gear is still extended.
- PMag Controller
Nidal Robb
Postby J Wales » Tue Mar 19, 2019 6:18 pm
Nidal,
I suppose any callout referencing “gear” would be sufficient to warn the the pilot who may have overlooked the gear. I get the “check gear” annunciation at 600’ agl on the AMS2000 if I remember to set the landing field elevation before descending.
Victor
J Wales
Users browsing this forum: Brian Campbell, Todd Johnson and 31 guests
