by Phil Sciuk » Fri Nov 22, 2019 2:01 pm
Need a fuel injector
I believe the part number is 652312-12E
by Phil Sciuk » Fri Nov 22, 2019 2:28 pm
It’s stamped 12E
- Attachments
by Christopher Toscas » Fri Nov 22, 2019 4:05 pm
ok,12E, P/N shall be the good one, I may check it some next day in the O/H manual (hangared), congratulations for bottom part successful unbolting.
For new one, use Teflon spray and no more anti-seize,
also put it on O-rings to slip cap easily.
If same trouble with other injectors, heat before unbolting with teflon also.
I tell it because I swapped many times one injector with one other to minimize FF spread.
Christopher Toscas
Users browsing this forum: Bing [Bot] and 25 guests
