by Stefan Hartung » Sat Nov 30, 2019 7:32 am
We are in the building stage where it is time to look for a propeller. It doesn't have to be new or freshly overhauled. Our engine is a Lycoming IO-360-A1B. Let us know if you have one available.
Thanks,
Stefan
admin on Sat Nov 30, 2019 7:36 am, edited 2 times in total.
Reason: moved to classifieds
Stefan Hartung
by Bob Fidler » Mon Dec 02, 2019 5:37 am
Did you try Lancair directly. I know they offer a very good discount. Ask them, you may be pleasantly surprised.
Bob Fidler
by Stefan Hartung » Mon Dec 02, 2019 10:01 am
We will definitely do that if we can't find a used prop. Thanks for the suggestions.
Stefan Hartung
by Mark Jackson » Tue Dec 03, 2019 10:34 am
Stefan,
Direct through Hartzell is approx. $15k, same prop going through Lancair Int. is 2/3 that cost. I just went through this and my prop gets shipped to me tomorrow.
Mark
Mark Jackson
by Matt Candelaria » Tue Dec 03, 2019 12:25 pm
Take a look at the f7666 blades. Mooney's require they are longer compared to the minimum allowed. What this means is this blade is available very cheap on the used market. I overhauled my prop after a strike replacing both blades. They cost $500 each blade. I think the whole overhaul cost me 3k. Johnson and Sons did the work for me and sourced the blades. Give them a call. You will also get better climb out of the f7666 vs the custom lancair prop (f7068). I have flown both on the same plane. The trade off is ground clearance is reduced for the f7666.
https://www.google.com/maps/place/Johns ... 19.1832746Matt
Matt Candelaria
Users browsing this forum: Bing [Bot] and 26 guests
