235/320/360/Legacy Landing Gear Controller (28V)
Postby Louis Gabriel » Fri Apr 11, 2025 2:51 pm
28V boards are finally in stock!
A complete, reliable, drop-in replacement for the landing gear hydraulic pump circuitry.
The Gear Controller replaces two intermittent duty starter solenoids, flyback diodes, Gear-In-Transit diodes, and all associated interconnects using the interfaces already present in the stock hydraulic system.
Features:
  • Solid state. No mechanical moving parts, no intermittent duty coil to accidentally burn up
  • Low switching current (200mA). Compatible with either stock or aftermarket solid state pressure switches
    Graceful startup and shutdown of the hydraulic pump.
    • Inputs have a 20 ms delay, which eliminates start-stop-start from bouncing mechanical switch inputs;
    • Motor outputs have robust flyback diode protection, which snubs voltage spikes on motor shutdown
  • Lightweight. The Gear Controller is half the weight of a single solenoid, and has a much smaller footprint than the stock system
  • Complete transit light solution. Wire your transit light straight from the board--overcurrent protection built in (automatically resetting, 500mA max)
  • EMI protection. The circuit has high resistance to radiated and conducted emissions
$695, available to order here (also more info): https://www.gabrielenterpris.es
Thanks for looking!
Louis Gabriel
360 Mk II
Re: 235/320/360/Legacy Landing Gear Controller (28V)
Postby Erno Ovari » Fri Apr 11, 2025 5:45 pm
I have Louis' 14V version installed in my 360 for a while now. Perfectly working and performing as advertised.
I love it.
Erno Ovari
Location: KSVR (South valley) - South of Salt Lake City, Utah
Postby Jonathan Gruber » Sat Apr 12, 2025 10:45 pm
Louis I plan on ordering this come fall/winter when I am doing more upgrades/mx than flying. Thanks for putting in the work on the 28v version!
Jonathan Gruber
Postby Clark Baker » Sun Apr 13, 2025 7:55 am
It’s really a nice product and cleans up the installation, allows use of the neat solid state pressure switches, and removes a fair amount of weight. Thanks Louis and Chris for producing it.
Clark Baker
Postby Brett Rhode » Sat Nov 22, 2025 1:53 pm
Do you have a 14V version available?
Thx
Brett Rhode
Postby Jonathan Gruber » Sat Nov 22, 2025 11:18 pm
Just ordered the 28V version! Thanks again Louis for producing these.
Jon
Jonathan Gruber
Users browsing this forum: Jonathan Gruber and 6 guests
